I have been using the fatcone bs on my rear truck with good effect on my traction, it works much better for me than a chubby because it allows more turn but retains the stably with more urethane, it acts almost like a taller pushing and I like taller bushings…The Krankz are the best for carrying any amount of weight and retaining rebound, I have about 235lbs on my deck when I’m riding and I still want a lively feel so I can carve and shred and the high rebound does that. I tried the WFB as well and they seems a little less lively, but super stable and comfortable…I tend to run harder duro on the bs of every truck and softer on the rs to tune the lean, I think of the boardside bushing (bs) to be the support of the deck and road feel, while the road-side bushing is used to tune the lean and carve, it depends on the bushing seat shape though and different trucks are different trucks, the surfrodz bushing seat almost provides a progress feel when using just a barrel while the same barrel in a Caliber will feel pretty constant and linear, best bet to to trial and error till you tune to the feel YOU like…it is sort of subjective that way after you get the functionality dialed or close to what you need…
I don’t ride anything else besides Riptide bushings now (a downhiller named Jake “wingnut” Knutson turned me onto them), they have one for everything. I have recently tried the new Hardcore barrels and they have a nice rebound as well, but no where near the options Riptide has when it comes to fine tuning. Ace trucks are the only bushings I leave stock, they just fit me well and my weight out of the box, I sometimes use Bones hardcore on tkp trucks for bowls and things when the stocks are just too soft for my fat manatee like body and I need to check out the shorter street truck options from Riptide as well.
I have some in the Liquid Attack tkp trucks and they are really nice in that truck, I wonder how they work in Bennet, Tracker, Independent…I have run Riptide barrels and fatcones and chubbies, in Arsenal, Avenue, Caliber and Paris, and they just feel better than anything I have tried. Blood orange seems rubbery, Venom seems mushy, Reflex are nice but limited to a few great uses like Bennett, and the Nipples are a weird size I only use in the Bolzen trucks where they fit better than anything else, they are like a street truck where the bs bushing is taller than the rs and somewhere between a tall and normal barrel…modern rkp tall bushing trucks like the Savants, Arsenals, Ronins, Roques and others are the best turning trucks I have used when it comes to bushings, you cannot argue with more lean and bushing in your trucks, you cannot have enough of a good thing, the fatcone comes into play perfectly here, and when you have more room for a bushing and add a fat cone, you can use a much softer bushing that has the same stability as a smaller one, and lean further with more stability…There’s also a lot of people using the bushing seat bushings now, many people who used a spherical bearing on the kingpin are now opting for a tuned bushing in it’s place and the downhill guys are going crazy over Roques for this reason, they are a cheap way to experience a tall bushing and insert…it gives you more to tune, but makes up for the lack of queenpin and helps keep the truck centered and from shifting…I love all this new technology, it’s a great time to be a skater, I hope people can start to understand it all and see what I am talking about. Without tuning to your weight and preference these advantages are lost. I recommend just dumping a 100 bucks on bushing and forming a little kit like I did, that way I have a box with all the options I might ever need for any skateboard build…
