BRAND NEW
Rayne Demonseed V3 Space Jam - Deck Only Length: 42" / 106.7cm, Width: 10" / 25.4cm, Wheelbase: 83.8 cm / 33”. Rayne Demonseed V3 Shipwreck - Deck OnlyThe Rayne Demonseed is the most comfortable speedboard on the market capable of reaching speeds you can only dream about. This board has a long wheelbase, TONS of foot space and a DEEP TUB Concave that is comfortable on long hill bombs while still gripping like a vice in the corners. For Maximum Versatility and Stability, the Demonseed has a 0.75? Dropped platform and drop-through mounting so that you can further adjust the riding height and truck angles of your board by adding riser pads between the trucks and the board.
New on the V3! New on the V3 models, the entire Gateway series is rockered, drop-through & have drop-platform decks. Double Drop decks are ideal for pushing your boundaries. The flex, construction and shape are designed to be stable at speed, have easy slide initiation and are low to the ground for long-distance pushing and commuting. The new rocker platforms help give riders more grip and will improve rotational slides.
Features
Sharp Edges – Final touch for locked in feet Vert-Lam Bamboo Core – Stronger than steel, light like a feather. Pre-tensioned fibreglass – Adds long life, durability, strength and energy return. Twin Shape – Freedom to choose any path or direction. Sublimated Artwork – Scratch-resistant ink is tattooed into the deck. Linear Drop Platform – 0.75? drop keeps your feet locked into place. Ideal for freeriding. Deep Tub Concave – Designed to cup the toes and heels for quick, precise turns. Universal Drop Thru Mounting – Lowers your board for easy pushing and extra stability. Rocker – Pre-loads your legs for easier tucking and turning. Bee Orange Finish – Enhances and tones the natural wood grain while protecting with an excellent wax barrier that repels water. The citrus-based polish is completely free of harmful chemicals and is an environmentally sustainable product.
Specs
Length: 106.7 cm / 42” Width: 25.4 cm / 10” Wheelbase: 83.8 cm / 33”. Construction: Bamboo & fiberglass.
