Hey guys,
What’s the definitive answer on bypassing the BMS on discharge! I’ve read that it can unbalance the cells too much. Is this true? Or are you overall ok…
Hey guys,
You’re fine as long as you balance charge
and as long as you use quality cells with a suitable battery setup not to small. Otherwise you´ll get drifting cells and the vesc is not capable of handling that.
Thanks guys!
