But since “CH+” is connected to the positive of the battery, doesn’t that screw things up?
Say the BMS wants to charge group 5, then it applies power to “B6” and “B5”. But if the “CH+” is also connected directly to the battery’s positive(through “anode B+”) that should screw something up, right?
I dont think I quite understood you there.
the charge+ is wired directly to the battery and the ch- is wired through the bms to have overcharge protection. ie the bms cuts power from charging port when the battery is full, the balance wires are for the bms to be able to balance each cell group and to measure the voltage of each cell group to be able to provide undervoltage detecion. ie to cut power out of the battery if a cell gets too low. you wont be having this last feature as you are bypassing discharge protection.
nothing screwed up here as long as you properly set minimum voltages in vesc so it wont over discharge your battery
Fair enough, I figured it’d be worth a shot since I’m only using it for charging. Once I get a hold of a charger I’ll test it for science and report back.
I use the same BMS bypassed for charging my 10s 10Ah Lipo since 2 months without problems (not that I recommend it but in my case it works so far, fingers crossed).
But @mccloed is scaring me, did you use this BMS for discharging, too?
Nope. Just charging. I gave another one a chance on a different board and had the same results but I caught it before it destroyed any of the cells. Sorry to scare you but this was just my experience. Hopefully you don’t have any issues.
