Just solder your neg coming from the battery to B- , the neg of your charger input to C- and leave P- alone.
Then just run your heavy guage wires directly from the positive and negative of your battery pack to your XT60/XT90 discharge plug which goes to your anti spark switch or directly to your VESC.
Edit: Oh and the pos from your charge cables directly to the main pos output of your battery.
got it figured out. Thanks! I meant: when the bms was used for discharge and charge the charging port was spliced from the main discharge leads meaning I could use the discharge xt60 for charge if I wanted
Yes. I have 3x 3s and a 1s 7000mah lipo that I connect together to make a 10s lipo 7000mah. Right now I take all the lipo out and balance charge them individually.
I want to buy a cheap bms and bypass the discharge. I am on the fence about this.
