I have a 12S4P battery that am using a charger that came with the pack. This charge is a 2 amp charge.
I also have a DC charger that can do 12 amp, does anyone know if the 18650 can support that amount of amperage or can the battery internal BMS handle the amperage?
Is anyone charging the battery pack at a higher than 1C rating?
Those cells alone in a 4P configuration can do 16A charge HOWEVER everything else, wiring, BMS, connectors, etc, all has to be rated that high as well, I guarantee the charge port probably isn’t, it’s probably a 4A charge port. Also, fast charging will reduce the lifetime of the battery.
Best bet is to use the stock charger and build another esk8, so while one esk8 is charging, you ride the other one
