So Im currently building another board, and curious about the APS Anti-spark.
Wanted to redo the cables as they were changed so many times before and started getting messy. Noticed however that the positive cable seems to be attached to another cable that just goes thru the antispark and then attached on the other side aswell.
Is the Positive cable just a cable that goes thru the APS with no components inbetween?
I noticed a quite interesting way of how its connected when I removed the shrinktube and it looks as its just a cable and the only thing thats actually affected by this component is the negative cable. You will see in picture below.
