I found a website with a calculator, however, it gave me a continuous amps rating of 100amps! surely my 10mm thick pack cannot do 100amps continuous… right?
Just wanted to know what to set my VESC to, to not harm my battery.
Thanks, Max.
Sadly there doesn’t seem to be any standard for measuring C rating so most manufacturers vastly overstate them. I think most peoplr assume they’re capable of half of what they say they are.
This is one of my favorite topics, and IMO, one of the most important subjects concerning Lipolys.
The statement made by @NickTheDude is (sadly) quite accurate.
For the best sources of information about lipo batteries, I recommend the various rc-hobby forums, as they often have been around for several years more than this one. Additionally, they tend to use lipo batteries exclusively for the power to weigh superiority. Not that this forum lacks in scientific talent by any means, but the rc-hobby groups seem to attract more, as not every geek is thrilled about skateboarding. I really mean no disrespect to our forum, but it’s good to look around for an enhanced degree of perspective. My go-to is rc-groups forum.
There is a tool that does exactly that, it’s called the "Wayne Giles ESR meter "
The Problem with 5ah 20C batteries is the voltage will sag under load so be careful when you get down to 50% charge because you could over discharge the battery very easily with voltage sag.
You should also look into the point of how much your vesc can handle.
Don’t know which esc you have but usually they rated between 40-60a bat constant max.
So in a single set up 80a would probably also fry your drv.
To elaborate on what @Namasaki is saying, those cells will sag individually at different rates because they will have different internal resistance. There are no two cells that are perfectly identical in their efficiencies, so one will be the best, and one will be the weakest. The difference between each may be small or large and the only way to know is either through precision measurements, or careful observation. There’s a lot to consider when using lipos, fortunately however, there’s a lot of information out there to help you find understanding.
The V-esc can read pack level voltage, but it cannot measure cell level voltage. The safest approach is to become intimately aware of each cell’s behavior and not push them to their potential until you know the weakest link
Edit: if you don’t find answers to your questions here, check out rcgroups, endless sphere, or many of the other forums out there, and you will
I’m using these same cells in a 1p config. Haven’t had experience with vesc undervoltage, is it a hard cut or will it just throttle down and decrease power until voltage stops sagging?
And @MaxMalouf I had a 10S2P pack with those same cells. I was easily pulling peaks of 50 amps on it when I really gunned it from a start. No noticeable voltage sag, even at near empty capacity.
But I’ve heard these cells vary frequently by batch.
The Vesc has a soft and hard back off strategy.
Low voltage start is soft
Low voltage end is hard
Even my 5ah 60c Lipos sag some under load.
You can bet that 5ah 20c Lipos will sag under load even in a 2p configuration.
How much will depend on several factors.
It’s not that noticeable to the rider but it’s there and you’ll see it if you monitor your voltage with an inline meter while riding.
Battery cutoff start at 36v
Battery cutoff end at 34v
You don’t ever want your Lipo cells to drop below 3v
Setting your cutoff at 31v would be very risky.
This is if you are not monitoring your voltage while riding.
I set my start at 34v and my end at 32v but I constantly monitor battery voltage by an inline volt meter mounted through the top of my board and usually stop when it hits 36v and I never go below 34v.
I also use a high amp bms that monitors individual cell voltages and prevents me from discharging any cell below 3v.
