I am going to use Caliber II in the back of my board by thought about putting Paris V2 in the front since Caliber II seams to be quite rigid. I will use 90mm wheels and most likely Loaded Fattail deck.
Lol, Calibers are more responsive and turn instantly versus Paris. Rake amount does not affect the turn radius. The only thing that affects turn radius is the baseplate degree. The higher the degree, the sharper the trucks can turn. I repeat RAKE DOES NOT AFFECT TURN RADIUS. If you want “better maneuverability”, then get 165mm trucks.
