Not sure if I interpret your question correctly, but the 3 wire red white Black is the ppm wire from one Vesc as noted but other end goes to remote receiver
Looks like sensor wires also in the corner of picture so need to connect them depending on what motors etc
Might want to search and read up a little more. Canbus goes vesc to vesc. RX gets plugged into master vesc. With canbus both have to be plugged (powered up) in at the same time. There’s more to it than what I said though.
Yes, thank you. that makes sense.
The white tipped black and white wire connects the 2 VESCs. Then the black goes from one VESC to the Remote receiver. Got it.
Some people do, I use 3m tape to secure it to the deck and just leave the factory heat shrink in it.
I’m almost out of 5.5mm bullets or I’d make you some extensions. If you wanna get some on Amazon and send then to me I’ll make them and send them back.
The jst connectors only go in one way. I would put some hot glue on the outside of the connectors once your vesc are configured this way they dont come undone by vibration but can still be taken off if you need to do work on the board
