Can i flash my VESC with that or did i buy the wrong thing? I attached a photo of my VESC, STlink and the cable i got with the STlink. On what pins do i even plug the cable on? here are the photos:
Your guide didn’t have the exact same equipment as mine so i was unsure if i could follow it or not! I’ve never done anything like this before so i wanted to make sure everything was correct
If you have a working VESC (ie running dual drive), you can flash one VESC to another VESC without STlink. That is a way easier method compared to using STlink given that you need a working VESC with the latest firmware.
Yep, you can flash it with that. I had to do mine last week after installing the wrong firmware. I didn’t have the cables either, so I just soldered the wires directly to the contacts under the VESC.
I am having issues with loading the firmware from one VESC to another. teh tool says “Could not connect to the target device”. i checked all my connections and they seem to be correct. I am following this link to flash it from Benjamin Vedder’s YouTube channel. is there something that I am missing?
