Hello, what do you guys say about this wiring diagram? Im not sure with the balancer wires. Greets from Germany! Louis !
looks just fine to me. just make sure the balance wires each have the correct voltage so you dont blow your bms. also, connect the main negative FIRST, then the balance leads
Once you get it all wired up, don’t plug in the balance cables until you check with your multimeter that the voltages are in order
make sure you have a way to power both vesc on at the same time.
Thank you very much guys!!
