Hello I go this remote, im able to pair it but can’t get my motors spinning, anyone have the same remote? Also which setting should I have the vesc transmitter just regular 2.4ghz ppm right ?
Have u set up ur vesc in the bldc tool yet? If not got to . They have great tutorials on how to program your vesc. You need to do that before anything
Yes I tried putting in different transmitter settings and it doesn’t work, my other 2.4ghz remote works fine
In which channel do you have the receiver wire plugged in?
The nano-x uses the same receiver and channel 1 is used for throttle and braking.
