Cant find 395mm belt
Hey guys, So I built a board recently but my belt is way to thigth 380mm I have torqueboard 6" pneumatique tires and Caliber II Motor Mount with Idler Tensioner For that, I think I need a 395mm - 390mm belt because I can only tension it with an idler (motor mount designs)
I can’t seem to find any belt that size and one that doesn’t have 100$ shipping (understandable I think :confused: ) If anyone could send me link and help that would be great
My board (using super thigth belts at the point I I cant even mount the idler to tension it)
can we see a closer picture of the motor mount & pulley etc.
side on picture
390mm
yea 1s let me get one for you
!! ! ME PUTING FORCE ON IT, 0 FLEX !
idk how you even got the thing on there lmao, yeah you want the belt to be able to turn to a 45deg angle but no more.
Thanks, and give the good cat a belly rub will ya
That’s really tight, don’t run it like that.
Typically one more tooth makes a huge difference, try 390 like has been suggested
Do you think I should get 395 because I currently have 385
I’d try a 390-5M-15 synchronous timing belt
410mm is far too loose if you were wondering
