Hey I’ve got some spare 63v low ESR quality caps and I know I should wire them in parallel but I’d like to use a PCB to do this. I’ve seen @onloop post about the Enertion one that VESC-X / FOCBOX use and have a couple of VESC-x (pre-FOCBOX).
Is there any source of Vedder’s design for this aside from Enertion?
I think that they will not be available to buy except as part of a FOCBOX
Wondering if possible to remove(snip?) or carefully break the PCB on either end to take off one of the three cap positions from the PCB without destroying it?
I bought these deluxe VESC cases and it would be a shame to not use them, to me only two caps will fit side-by-side in it
So OshPark delivered me 3 superbly made PCBs, room for 3 caps on the board, but like I said it would have to be cut down to 2 caps for teh VESC enclosure I have.
Here’s the thing though on inspection of the Vanda VESCs, they seem to have one brutish cap hard wired in, 63v and 200Uf capacity, wondering if that is enough? Seems to be X 100Uf caps in a FOCBOX, so maybe this is a pointless step I’m doing and should just through them into the enclosures and be done.
Voltage spike with a single 2200Uf 63V cap, that’s not going to happen right?
Traces in this pcb are so simple you can make your own with 2 copper pieces and some random piece of wood, plastic or whatever non conductive thing you can find
If you search the rc forums, the rule of thumb most are using one small cap (230/280? or something) per 10cm of battery-esc wire. Apparently smaller caps have some marginal gain over larger ones.
Some of the manufacturers are recommending this in their literature as well.
edit: I had a look at my YGE cap banks and they are 63v 330uf (x5) and 390uf (x9).
