Heck, post some pictures. Im hella curious now
Ok when I get home I will post some pics.
Yeah, on the other side of the cable sure. But what about the chain from transformer to output?
Gotta go. Please keep posting this and ideas that I can take a look at soon and I will be back soon
You really want him to measure that? No offense @dg798 but electricity is hella dangerous if you donāt know what you are doingā¦ especially mainsā¦
Just promise you wont go poking around into a live box without guidance.
If he knows what hes doing, Iād do it without hesitation. Iām an EE tho so I know what not to do
Me tooā¦ (learning to become one)
I donāt think he knows what heās doing and if he doesnāt know where the mains side is he could get seriously injured
I wouldnāt trust any fuseā¦ itās youāre last line of defenseā¦
Lets hope weāve nagged enough about safety. Fuse part is just to make people think, some countries still dont use residual-current devices so current can run until the cables meltā¦
Mains side is what connects to the outlet
Yepā¦ but please donāt poke around with your multimeter when itās plugged in.
I only did that when I wanted to test output voltage.
Listen to the guys here my friend. Not much inside on of those things that are user repairable and cost wise its usually cheaper to discard and get a new one. If the indicator light is blinking rapidly then its a component issue not a wire fault so again probably not something you can repair cost effectively. One thing to note too is sometimes when you unplug the charger from the mains the indicator lights stay on for a time. Thats because the unit holds voltage so even unplugged you can get a belt. Give it a while before you touch anything after its unplugged. For future reference when you charge the board, plug the low voltage side in first ie the board then connect it to the mains. This will stop the spark from the charge port. It will even spark on the port if the outlet switch is off. Be safe!!
While rcb are the safety standard for new installations there are still a lot of old residences that have not yet been ungraded so caution is a bloody good idea lol
Always good to have more than 1 charger at home that way you always have one available even if you left one at work or in the car. Also helps eliminating the charger as a problem if both chargers donāt work that usually indicates itās a problem with your board. If only one works and the other doesnāt then you have a defective charger.
Heās in the US so itāll āonlyā be 120 VAC
True 10 charc
Thanks for the tips guys. Appreciate it. Gonna buy a new one from @JLabs. Are his chargers legit?
Yesā¦ 10char
