Does this pic mean anything to anyone? It looks like I burned up my 4th cell balancing resistors. Does this mean I should only charge up to 3s with this charger?
Just replace the resistor if the traces are okay…
the resistors are 121Ohm what seems to be 1206 package (1/4W)
but if you burnt these resistors, you may have a damaged mosfet/transistor.
Transistor looks okay but who knows. Can I still use this charger for 3s until I get the resistors swapped?
I think no ones can answer this question correctly. If you still want to use this charger, its on your own risk.(I would not use it ;))
I believe you burnt your 3rd cell resistors so you’d be able to charge 2s if the board still works. Btw, how did this happen?
I agree with @chinzw you burnt your 3rd cell resistors, you should be able to balance charge 2s, but you can still use it to do a regular charge on any li-po. you can still balance by charging each cell individually
It is the 4th cell balance resistor. It is set 4 of 6 in the pic. It successfully balanced charged a 3s yesterday.
I made a series adapter, and it didnt like it. Do you see any problems with it? I think it shorted cause my joints are not taped up real good…
That’s not how it should be wired. This is how you do it:
And if you mix your positive and negative leads you’ll fry something too
That leads looks fine just maybe more heat shrink. It also depends how your main +- are wired so take a pic of this and the batteries wired up together.
You had the battery balance leads the wrong way around and burt up your resistors as a result. You can remove that bank of resistors and replace them and probably the little transistor on that bank too. It should still be ok after you replace those components
The idea in my case is to make sure both red wires come from the same battery correct?
How does this look?
I think it looks ok, to make sure, before you plug it to the balance charger just measure the pins to make sure they’re working and wired correctly and not inverted
you should get 4.2,8.4, etc if at any point you get a jump bigger than 4.2v then they’re wrong.
No don’t think that looks right connect your batteries as well so we can see them connected to make sure.
