Hi,
for now I use 3x 3S LiPo batteries connected to get 6S pack (2 pararrel packs connected in series ). I have a problem with overheating after 2-3 kilometers
My VESC restarts and loose connection for a while. I just suspect that it is caused by vesc’s overheating. I don’t have space to add additional cooler or radiator-like thing (look at photo; I can’t place vesc close to relay because it is too long - I’d have to resolder motor and power cables in vesc).
Finally, I decided to connect bateries into 12S LiPo pack to lower current so maybe it will help. I ordered appropriate 12S LiPo BMS, and now I’m looking for power supply for it. According to Vlad’s instruction ( http://www.instructables.com/id/Fast-Electric-Skateboard-LiPo-Charging-System-BMS-/ ), I want to order similar power supply (in my case 48V, 5A - 240W). Instruction seems to be clear but my knowledge about electronic is not too wide so I would like to be sure of what I do My question is: Will it work? And is this power supply ok? I wonder about soldering potentiometer to higher voltage. I suspect that not every power supply is the same, so I propably have to figure out where to solder potentiometer on my own.
Has anyone made something similar? Maybe any tips about choosing correct power supply? Do I need documentation of it?
