I have just recently removed a dead cell from my 8S pack, as described in this thread..
New problem is that I need to trick my 8S charger into charging my 7S pack. I have made my own charging port using a D-Sub15 pin plug (essentially a big VGA plug) and now I just cant figure out how to re-wire it to make it work.
You have 9 pin connector and 9 cables. Remove first or last cable. Use 8 pin connectors. Done. Seriously, not sure what’s bugging you, it’s the simplest thing
putting un-balanced cells together in a single battery aside…
the cells would all need to be in series with the 7 balance wires in a single balance lead… be careful. you will need to watch charge and discharge voltage constantly. you don’t want a fire
The cells were all balanced to ±0.02 difference in voltage
For sake of simplicity, lets just assume i had a 7S battery with a single 7S balance lead. How do I connect that to my 8S balance lead on the charger? Thats ultimately my question
Well on the manual it says its capable of charging 2-8S batteries and it also originally came with a balance board (its long gone), so i am assuming it can
No i am hooking up the balance leads into my vga port, so that i have a plug’n’play solution without bms, so i am not actually using the jst plugs on my lipo
Alright, yo need to make a cable that will connect (-) from the charger to the pin 0 on the VGA, following through pin 1 (4,2V), 2 (8,4V)… up to 8 (29,4V). Pin 8 will finish at marking 7 on the charger. 8 on the charger will be free.
No problem. If your charger doesn’t have auto detection and selection of number of cells, make sure you switch to the 7S mode.
BTW, where did you get the charger?
