I’m getting two 5000mAh 4S1P 30C with XT90 that I will connect in series with this.
Was thinking about getting this BMS and connecting it to a laptop charger like this
Adding a BMS to your battery setup is great!
What do you mean about our thoughts?
A lot of people on the forum build their batteries with a bms.
I would not use the BMS you listed though.
It has a max discharge rate of 10A cont. which is to little. You will either have to buy a higher rated BMS or bypass for discharing. There are a lot of people using BMS from Bestech or Supowersupply. (Including me)
I would suggest going with the 60A/80A model if you ant to discharge through the BMS.
You can use whatever connector you want man, just buy a female and a male and solder them on. However the BMS doesn’t come with connectors if that is your question
I would suggest reading up by searching on the forum about how this works.
I am sure there are Lenovo chargers which does 33.6V, if not there are other brands.
Yea that should work, an 8S Li-ion charger for a 8S BMS.
I would search of charging in the forum, if you want to learn more about batteries, ebikeschool on youtube has some great videos.
