I have a 10s3p battery that I am going to build with a BMS. There will be an antispark switch in the system. Do I need two connectors coming from the BMS, one for charging and one for the esc? When I do charge the battery can I just simply unplug the antispark and then charge it or do I need to disconnect the ESC as well?
The schematic my BMS came with says the charging port and discharge port are the same positive port. Does this mean I only need one wire for charging and for the ESC? For some reason this is confusing me, I don’t want to mess it up.
My bms, 10s2p is wired with one male xt60. I use that to plug into esc when riding and when I charge I unplug the esc and plug the battery xt60 into the charger. I can snap a pic later if you need. Lmk.
The chain is:
42v 2a charger -> antispark -> watt meter -> battery.
Watt meter is nice because it shows the current volts and amps too. I’m running a kitchen thermometer probe to watch temp since this is the first time charging the pack. To sum it up though, you can just have one plug on your battery and then plug the battery to the charger or your esc.
Also, I bet if you check continuity with a multimeter you’ll see that all negatives are connected. Hopefully this clears it up.
