I made my first diy eboard (single motor) but I cheaped out on the whole drive train (trucks,mount,pulley,belt) and it just sucks because it gets loose and the screws are really cheap so I had to use glue but it moves a lot, it’s just a big mess
I’ve used this vanpro mount and clamp and it’s a pain in the ass. For caliber trucks you’ll need to file a flat spot inside the clamp. Whenever you get everything aligned, assuming you are aligning properly, screw the clamp down leaving marks. Take it all back off and drill into the truck like 1/16 of an inch using a 3/16" bit in all 3 spots. check for fitment one more time. Now get some 5 minute epoxy. The good shit. Scuff the spot where the clamp sits. Mix the epoxy and goop it on the clamp then put it on the hanger and set the screws into the holes you drilled. If you did everything correctly I assure you it will stay. And if you do the epoxy right it won’t look as bad as it sounds. Loctite your motor screws with blue loctite, same thing with drive wheel pulley, loctite those bolts to. Should be good to go. My PayPal is [email protected] my free advice is on special right now for $3995.95
P.s. fuck you if it doesn’t work or you don’t like my system
P.s.s. just kidding. Be safe
