Hello,
I want to offer some CNC milling services to the esk8 community! For my own build I milled all the plastic for my casing, the aluminum for the motor mounts so check out my build for those examples. I currently have a bunch of 10 inch by 12 inch pieces of 1/8 inch thick 6061 aluminum, and some 1/4 inch scraps I could use. I also have wood that’s great for prototyping ideas as well as parts. So sent me a message if you want me to mill anything and we can discuss cost. Attached are pictures of the aluminum blanks and what I have been milling them into! (Brackets for Gpu mining rig cases).
will have a fast turn around but have to work around my full time summer job
just need 2d or 3d models of what needs to be milled
you can send me the metal or plastics or other materials and I can mill what you need! Or I can purchase and include into the costs.
@willpark16 I think it would be doable and am willing to try it out! I would like to do a few tests as soon as you have a cad drawing of it to make sure I can get it lined up perfectly. So it just used regular plywood? Also, I don’t have ball nosed endmills though so the bottom cover wouldn’t have tapered edges. That could be achieved with sanding though.
In general, you have to machine the parts by yourself for some projects are not in urgent, that means you can offer technique support and outsource machining parts for your client to earn money.
