Hello! I am now building my first electric longboard for cruising on the streets. I have done a lot of research but could use some help by the professionals. My goal is to have an electric longboard with extremely good specs and to make the ultimate board. I want my board to go very fast, have good torque and a long range. I have gathered som parts from different stores online and my main question to you is if the following parts will work together?
Battery:
BMS: ??? (please come with suggestions)
Deck: https://www.hi5ber.com/ion38
or
Truck: http://avenuetrucks.com/longboard-truck/
Wheels: https://sharkwheel.com/70mm-80a-black-mako-longboard-wheels/
Motor: 4x of:
Pulleys: ??? (please come with suggestions)
ESC: ??? (please come with suggestions, I would like one with regenerative brakes)
Belts: ??? (please come with suggestions)
Remote Controller: ??? (please come with suggestions)
When Giving me advice on other parts please find compatible ones and ones with very good specs. Here are some other questions that I would appreciate if you could answer. Will all the given components be compatible with each other? Am I missing something? Is something unnecessary? Do you have any other alternatives? Are any of the mentioned products of bad quality? Is there any chance that any parts will break with the chosen combination? What determines if you have BLDC or FOC? The motor? The ESC? The remote?
Thank you for taking your time! Sincerely, Eric.
