Just planning layout of my single drive build. I’ve got a Comet Loki which is a drop through board. Gone for 90mm wheels to raise it up a little but just checking ideas for clearance. I’ll be making my own mount so can be flexible with placement. Initially thinking out the back but how close to the centre of the truck and the ground is OK?
I think you still need a riser. When you have motor mount, the motor position stay while the deck is tilting around. So you have to keep those clearance in mind. 1cm spacer is pretty good.
