Hello!
I have decided that I’m going to sell my Trampa Mountain board. The reason? It’s too much work for me. I’ve decided that even though an eskate is extremely fun, it’s not what I expected it to be when I built it last summer. Things break, and I have to repair them, and I simply don’t have the time or energy to do it.
So I want to be clear from the very beginning - this skateboard is not working right now, and that’s how I’m selling it. As I said, I don’t have the time or energy to repair it. Don’t buy this board unless you’re prepared to fix it and know how to.
I am 90% certain that the BMS is at fault. If you replace the BMS it should work again. The other 10% goes to the ESC (or ESCs as there are two of them). It could be that one or both of the ESCs are broken as well. Lucky for you, though - if you buy it, I’m sending you an extra unused ESC that I have laying around - for free! So if you’re good at math, and you trust my troubleshooting, you’ve probably realized by now that you’re 90% sure to get an extra ESC for free. (Yay!) Oh, and you also get 2 unused Enertion Nano-x controllers for free, just cause I got spares I don’t need anymore.
The brakedown happened last summer (yes, I haven’t touched the skateboard for a whole year - I told you, no time or energy). I was on my way home from work when the board just suddenly died. Took the bus home instead, and opened the board up to find that the positive wire from the battery pack had somehow managed to rub through the heatshrink and short itself on the BMS, which in turn had turned black in that area (pictures below). Didn’t want to fix it right away, so i kept letting it sit there, and all of a sudden it had been a whole year. So now I’ve decided that it’s too much maintenance to own a eskate, and that’s why I’m selling it as is.
I know selling a non-working board brings down the price compared to what I would’ve got if it was working, but i just can’t be arsed anymore. I want to get rid of it.
So now to the specs:
- Trampa HS11 plain deck, 17 ply
- Trampa Superstar Rims, White with Black spokes
- Trampa INFINITY Trucks (12mm Solid Axles)
- 2x Trampa 136 Kv motors
- Trampa Urban motor mounts + 66T pulleys
- Trampa 6.5 Inch URBAN Tyres (mounted)
- TRAMPA 8 Inch TREADS General purpose Dirt (Extra, never used, with tubes)
- eBoosted 12S4P battery pack for Trampa HS11/HolyPro
- eBoosted Trampa HS11/HolyPro 35 Enclosure
- 3x FOCBOX ESC (2 mounted, 1 extra)
- Battery Percentage display, Blue
- 3x Enertion Nano-X Hand Controller (2 extra)
- Eskating Anti-spark power switch
- 4 Amp Fast Charger (12 s)
- 6W Waterproof Led light kit with brake control (never used - not mounted)
- 2x 15T pulleys (mounted)
- 2x 14T pulleys (extra)
- 2x 13T pulleys (extra)
- 6 Belts (2 mounted, 4 spare)
- MBS F5 bindings
What I’m asking for this package, with a lot of extra parts, is 1800€, which I think is a pretty fair price, considering it cost over 2500€ to build, and it’s only been used for about 3-4 months. The rest of the time it’s just been standing, untouched.
Now, here comes the pictures:
