So far everything seems working OK but it’s my first board so I don’t have any experience. It feels a little weak even riding up flat hills and I’m not sure if its because of some false settings.
Also there seems to be a problem with the battery. I got voltage cutoff at 40% battery level at every ride.
Battery cutoff is set as suggested by vesc tool.
Does this mean the battery is broken? Or the bms? Or some settings?
Also if you are planning to store your board for the winter, leave the battery at storage charge, and check it every couple of weeks at least…many people let their batteries unatended resulting in catastrofic failure, money wasted…
I know about the storage charge an it was in regular use for bench testing.
But from the first ride on it always died at 40%.
I’m not sure if the battery is broken or the bms. if it can be repaired or if I need to buy a new one.
You can check your P groups (the internal battery resistance ir), it could be a something simple or it could be thet 30Q are not original…Also you could set up your cut off numbers using the following Esk8 calculator https://shop.3dservisas.eu
At 40% maybe they are saging enough to activate the cut off end of the ESC or the BMS if its set to charge and discharge balance…
I would mesure the P groups ASAP…Check everything its ok…internal resistance it is a must, to at least know how are the batteries holding up…Just to let you know, if your battery sags to much, you will activate the BMS discharge protection if you have it running, or/and the ESC…Lest says you push your throttle hard at 37v, and your sag is 6v for any reason, 37v-6v= 31v …and then cut of happen suddenly…
for the 130Kv pass 15kmh they starts to pull and bring you up to ultrasonic speed. 0-15kmh is their weak spot, don’t push them too hard there. They ask a lot of current to produce strong torque, due to the low efficiency at lower speed. If you are capable you can switch to wye configuration of the motor terminal and they became the 75kv version. Much much better.
I’m not really sure how to check the ir. I only have a multimeter.I also have the ackmaniac app and some recorded data. But there is no voltage staging visible ecpect the moment the board turns off at 40%
I measured the voltage of the packs:
Pack 47,7 v (80%)
43,6/4,1
39,75/3,85
35,72/4,03
31,68/4,04
27,65/3,48
24,17/4,03
20,14/4,03
16,11/4,03
12,07/4,04
8,04/4,03
4,02/4,02
0
So there seems something wrong with nr 2 and 5.maybe not balanced correctly?
Thats it is not balanced…Also 12 is 0? that is dead…Your should check at forum…If 12 is dead you need to change the P group depending on how much use did you put on the battery…You have to balance every P group, the lowest voltage in a P group is goind to cut off the bat…As I mention before, go to the other forum and ask at the newbies questions, you will get tons of help…
