I’m working on my first build and have discovered that both my VESC (TB 4.12) and battery (10S3P with solid state on/off switched attached) have XT-90 male ends on them. What is the preferred way to connect these two ends? -cut off xt-90 male on VESC and resolder a female end? -solder two xt-90 female ends together back-to-back to create an adapter that will allow me to connect these two? -some other solution that I’m not thinking of? Here’s a photo of my setup:
Just cut off one connector and resolder, cut off the VESC connector and not the battery, if you switch the battery connector make sure not to short it
solder a male some thing with a male plug on 1 side, and a female on the other (a converter)
Why have 4 connectors when you can have 2?
true… 10chars
Wow who gave you a battery with male connector? Dat shit is pretty easy to accidentally short.
I bought it from mboards.co Now that you mention it I think it WAS a mistake. The photos of their product show female ends: https://www.mboards.co/collections/electric-skateboard-parts/products/10s3p-battery-complete-battery-solution
