Connection from receiver to VESC
Hi
Have a FS-GT2B Transmitter with a 3 channel FS-GR3E receiver. Was wondering where to connect to on VESC and what terminal are used. Wiring diagram would be helpful.
Thanks
The PPM Signal / RC Servo is where the 3 pin of the GT2B goes. You’ll need to either solder a 3 pin to the VESC and/or solder a servo wire directly to the area.
Most of the VESC’s you purchase will have the 3 pin however.
you’ll find it somewhere in the forum . its all in here at esk8
Here’s a schematic. Some cables are black/red/white and others are brown/red/orange. I’ve put both on.
Hi There,
once I’ve connected everything up and binder the receiver will the VESC operate the motor or do i have to program it first.
Hey Kruizy, it sounds like you need to do some more reading, the vesc is fairly straight forward, but if you don’t take time & do your reading it will likely end in tears. :smile:
click this: http://www.electric-skateboard.builders/search?q=vesc%20faq
