I’m kind of at a loss right now. I can’t figure out why I’m all of a sudden having connectivity issues. Now it’s to the point that whenever I apply throttle, it will cut out on me after a second. After this occurs, if I try apply throttle again the motor gets glitchy, slightly applying the brakes/locking up for a split second. My guess is it has something to do with the motor. Maybe the internal wires are shorting or something. I really don’t think it’s the remote at this point, but I will definitely look into it further. Fyi, It’s a Steez remote - pretty much brand new. I did recently change a few of the Vesc settings, which were as follows: Motor tab: Unchecked Limit erpm with negative torque, set max erpm to 60k, PPM tab: erpm limit start to 58k, erpm limit end to 60k, min/max pulsewidth to match what display was showing. Also, changed motor/batt min (regen) to 30/-30 to ease up brakes. It’s set as current no reverse with brake.
Any help would be greatly appreciated. Thanks much!
I would run motor detection again too. I’ve had vesc reset randomly.( Maybe I tapped the wrong button?)
But it would cause the motor to stop after a sec…
Strange, everything looks good. Still have a couple more places to check but I’m stumped. Still wondering if the motor wires could be at fault here. Could there possibly be a short where they meet up inside the motor? Was thinking about replacing them with some silicone wire.
@mmaner@saul Looks like I found the culprit. Bad solder on motor or vesc bullet connector. We shall see if this fixes the problem. Thanks again for you input.
