But instead of a brass busbar I’ll probably use a copper one, and I stumbled across a copper sheet which looks good. But on the product info the electrical conductivity is measured in ohm/mm2.
Does anyone have any input on if this is a good sheet to use for this application? The product info states 0,024ohm/mm2 @ 50 degrees celsius.
I’m guessing it will still be way better than nickel but hey, maybe there’s a copper specialist in house
Not splitting hairs - copper is the metal of choice for conduction due to its low resistance and other physical properties, thats why you find it everywhere in electronics…
Actually, gold-plated silver is the best conductor known at room temperature.
Silver conducts the best and gold makes the best connections to other things.
0.5mm. The length of 3 18650 cells (I’m in bed and I an hesistant to go measure cells atm, my wife is starting to worry about my esk8 addiction) and probably 10mm in width.
can i ask a question here without derailing the thread…
isn’t a certain level of resistance necessary in the metal of choice for bridging P-groups so that balancing occurs more thoroughly between cells on charge and discharge? i know copper is available, and i know that its far more conductive. That’s literally what coper is known for and we learn that at a very early age.
this question is not motivated by giant spool of nickel i have.
Gold is the least conductive of the two, but it makes the best connections to other things. No electric can flow through it inless it’s connected in a circuit. So silver in the middle and gold plating works best
partly because it doesn’t corrode at all, making it ideal for permanent connections such as in home theater systems and other areas where signal integrity is paramount.
According to some hasty Google-fu, 0.5mm copper has a resistance of 0.000847 ohms/square. For a 10mm wide, 50mm long strip, that would be 5 squares, or 0.000847*5=0.004235 ohms end to end.
yeah my artist brain is smart, but not so much science and math smart, just imaging and producing things from nothing kind of smart.
sometimes i wish i could hot swap the kinds of smarts i have, then i could leave myself dtailed notes in plain english when i’ve finished mathing a problem and need to art on it.
Ideally you want the least resistance because any resistance would mean a voltage differential which would mean uneven discharge and/or balancing. At least that’s what makes sense to me.
