i have all the same questions.
my thoughts were that the fuses allow a gentle overload cascade to happen that will eventually burn up all the cell fuses in the p group, disabling the pack, and i have to assume burning up the balance lead as well if the BMS doesn’t sense some dumb shit happening and switch off.
so then what… you replace the cells?
so after reading this whole thread repeatedly while trying to take the occasional break in order to draw pictures of urinating esk8ers, i was lead to the conclusion that having cell “go dud” inside a welded p-group was somehow super-bad-time, either the cell would drag everything down with it and not accuratelty balance things any more, or something worse like extra heat …
except i’ve never seen any of this happen and i’ve had every kind of bad battery come across my bench conceivable. I’m not saying i’ve seen everything, i must assume that i have not. but i have seen packs with far less than adequate cells sitting in the middle of a 4P group doing nothing but mildly affecting range and full charge voltage.
