That sounds like a charger issue not a battery issue. Not trying to change your opinion just giving my opinion.
Iâm on the process of building a portable light board, but I donât want to look funny because itâs too small, so I chose the Moonshine Sidekick 35" will install a 10s3p, 90mm Wheels and dual Focboxes.
So expected range of about 10-12 miles? I am looking a doing a similar thing with a trampa street board. Deciding between a 10s 5ah and a 10s 10ah pack for it. Do you have experience with wh/mi?
Sounds good! I was wondering if the conventional Boards offer enough width for bolts, that attach the enclosure. 'Cause I built my own Longboard and I nearly had troubles with fitting some good bolts, without them looking out the other way
Well I just thought if Iâmgoing for a shorter board, it will safe me some space, weight and cash. And since I wonât be going fast anyway, I wouldnât need more Voltage
