Potentially. The 6355 will though.
I have a 5 wire one I have one of that connector at home is there and porticular colour code in connecting it do you have any pictures
You need the JST 2.0mm 6pin connector. This motors are the same motors you can get from banggood or aliexpress
Which of the wire I leave out,on the motor sensor there are only 5 wires
You leave out the temp wire
What’s the Color arangment
It will say it on the pin out on the racerstar website what each wire is and then you just match it to the vesc plug. That is not the jst 2.0mm
