This is my first post and I do not know what to really expect from here, but I am looking at making a custom board and want to know if anyone knows if this build is compatible. I do not know what the board (Like the bamboo or carbon part) is going to be but this is what I plan on using and if someone can help, much appreciated.
-2x flipsky BLDC belt motor battle-hardened 6374 140kv 3500W
-chibattery custom 21700 12s9p
-stormcore 60D
-Flipsky vx2
-ownboard trucks on rear
-Evolve trucks on front.
I do not know if this will work. From what I have seen it will.
I was looking at the boundmotor deck. Its a bit pricey for some reason but looks nice. I do not have the parts yet. I am on here trying to see if they all work together. Because thats a good bit of money to spend if its not going to work.
This guy named ricky “average esk8 reviews made on with a similar build. The difference is I am getting a batter battery and Esc. I want to know if I will have problems with the 12s9p battery size.
I’m a newbie so I don’t know it that well, but I don’t see the gearbox. I now compose Flipsky vs Trampa open belt. I had to turn and grind … Although the axis is 8mm, from the motor is 1cm axis 10mm, then 8mm. He had to turn 5mm. Then the bearing from Trampa is 7.86mm - Flipsky axis 7.96mm. It can be pressed, but I don’t know how to take it off in the future, that’s why I had to sand 0.1 mm with sandpaper … My English is terrible, maybe it can be seen from the photos. It’s a little more work, but I enjoy it.)
