Hi, I’m 40, new here, never been on a esk8, but I’m ok in rc, electronics and diy. What I want to achive is something inspired to this:
It should be cheap, and not too powerful, looking to around 10-15 km/h and 10km autonomy, and go over cement and normal uneven streets. I want to build this upon a IKEA trolley:
using a wide truck fixed to the bottom of the bag, and a single e-wheel on the back, so that one could use the handle to help standing while driving. The board should be kept inside the bag if not riding, and someway mounted in place to ride.
I’m trying to find the right components and I need some help to avoid stupid choices!
My known numbers are: front wheels should be something like 80mm-100mm scooter style, mounted on a wide truck to have the wheels outside the trolley-bag. So maybe wheel like this?
and this truck:this truck is cheap and 15inches wide, which can be ok, but I don’t know if I can mount scooter wheels on that. what I read essentially is that it has 10mm axle, so should I change the bearings, or can I find wheels with 10mm bore?
Driving wheel can be smaller, like 80mm maybe… and the mounting frame will be designed and 3D printed by me. After that I made my calculations, and found out that with: driving wheel diameter: 80mm battery: 6S , 22-24V(I’m still not calculating power…) ratio: 3:1 motor: 160kv realistic max speed should be around 15km/h
Do you think a 160kv motor can be a right choice? what should you suggest to change in case? Thank you for your interest and suggestions.
