We are going to offer custom loop keys
With a X,Y,Z custom lengths
X- input from battery
Y- loop( key )
Z- output (single or duel)
Custom connectors T60 or T90 (in/out)
$10 for single T60
$15 for duel T60
$15 for single T90
$18 for duel T90
All loops are T90 ( off set ) anti spark connectors
T90 duel
T60 duel
These look very nicely made. I would always use the male part as the key though. Then you don’t have the two male live prongs exposed on the board when the board is off, if you see what I mean?
It’s ugly! But the other way is still only clean when you don’t have it plugged in. When you plug it in, there’s still the key sticking out at an angle wherever you put it. Unless you make it like the folding one that showed up on the no words thread.
An advantage to this (female as key) is that if the resistor were ever to blow, you could easily just get another without having to disassemble your board
True. I thought of that. It can work both ways or be done both ways. One will limit your mounting area
The possibility of the two prongs touching or making contact is highly unlikely with out help It’s true with smaller prong type connectors.
It would be preference and how it’s going to be mounted.
I am working on a close ( none wire loop )
I’m going to have some 3D thumb drive style handle printed and glue the connector into it versus a wire loop
For sure the cleanest
I wish we could see some other nice and easy implementations of something like this
Or that maybe someone would spend time designing a hardware cutoff like the XT90S but purpose built for esk8 like we have been trying to do with antispark switches
It’s just so hard to find a good switch.
I’m tempted to go back to the luna switches but they burn out just as fast. It seams flipsky switches have issues with 12s batteries.
the Vedder switch is just outdated.
So far the mini momentary switch the unity has works well.
seems that integrated soft switches in the esc are the way to go.
or loop key
When the switch is integrated into the ESC it can be on the other side of the power filter capacitors, which has the effect of allowing it to NOT burn out, but also has the side effect of allowing the capacitor’s leakage current to slowly chew away at your battery while the board is turned off. It’s like there is a tiny piece you can’t turn off. Unless they have a digital switch with separate precharge resistor & FET, which I doubt.
the fat boy switch is impressively large, I haven’t seen LHB switches yet. I would be interested in its size.
with all the upgrades and tight spaces its difficult to find a good fit
