Hey
I’m about to make my setup using two VESC in dual mode via CAN, is there a way to get information out of both boards using only one seriel connection ?
I need things like, Current, Voltage, temp, mah, mwh… I have seen people reading these things through the UART on the VESC, but only for single boards…
I would like the information, to show it on my upcomming remote with a build-in oled screen… But would be neet to have the actual data from both, instead of multiplying the numbers, and guestimate the actual current and so
Please feel free to point me in the direction of docomentation explaining my needs
There is a COMM_FORWARD_CAN command that I suspect might be able to be used to forward the data via canbus. But that’s as far I’ve gotten into sending data between vescs. It’s on my longer term to do list for sure.
I’ve been trying to figure out myself what is being sent and what’s not. I though the only thing that all vescs have in common would be voltage and rpm. I’m pretty sure current is different per vesc. I only see 18 amps max which is my limit on each vesc. And x4 would give me my overall limit of 72 amps. The numbers make me believe its only one vesc in the current numbers.
It is possible, just hasn’t been implemented in any application to my knowledge, mostly due to not really having a need for it, since most of those parameters are very close to the same on each VESC (as was said above).
Edit:
BLDC Tool has implemented it actually. I forgot that I tested it a few weeks ago. You can fully write and read the secondary VESC connected over CAN-Bus via the bluetooth connection on the primary vesc.
