So, basically I rode my board about a total of 5 miles and the battery died so I came home charged it and the VESC was still working. I unplugged it to charge the battery and when I plugged it back in, no lights no nothing.
Edit: and how exactly do I know it’s the VESC thats dead? My battery is also not charging. I don’t know what’s going on at this point
This is now a conversation about avoiding a broken bms
Jeez I actually figured that out moments after I posted this, but I had to leave for work. I’m running a 10S2P of LG HE2 with a 10S BMS, which I’m pretty sure busted. It won’t charge, it keeps dropping voltage, and no current is actually going through the BMS(I connected an XT90 with 2 loose leads and it didn’t spark). When I get home from work I plan on bypassing the discharge of the BMS to make sure the battery is ok. @JohnnyMeduse
Everything works fine without the BMS so definitely that. But I don’t know how it happened /how to prevent it from happening again. I’m assuming the charger somehow friend the fuse or it got confused with discharging and recharging and just died
