Following my recent fun with tearing knee ligaments I have decided to add a deadman’s switch to my mini remote…
I’m thinking of a hand grenade style leaf, activating a micro switch, in series with the power switch and reducing my remote timeout to 0.1 seconds. I’ll be adding a Lipo and charging circuit at the same time.
Before I start on the cad modelling does anyone have any opinions I need to hear?
I’ve found that a dead mans switch is actually dangerous for me. It means I can’t switch my hand position or I risk activating the switch (releasing the button/lever). This causes hand fatigue and if it fails at 30 mphs your screwed.
I personally don’t see the need for a dead mans switch unless it’s going to slowly brake. Because if you say dropped the remote, it’s going to stop itself anyway
It’s also if you accidentally accelerate. Say you’re holding the remote and try to put the remote down or in your pocket but forget to turn either off. If the wheel (on the remote) is pushed forward, you’ll go flying or your board might to into the street.
This is unrelated, but is there a way to know when the torqueboards mini remote is near the end of its battery life? I would like to avoid it cutting out on me all at once.
I’m in the U.K. the current behaviour of my vesc is ackmaniak timeout braking which is progressive. When I’ve tested it it works well at not killing me even at high speed. The style of dead man I’m considering would need a full letting go of the remote to deactivate…
The R2 style deadman switch that only activates below a certain speed (2mph?) seems like the way to go from an accidental “launch my board into traffic” perspective.
It won’t interfere with your riding but it’ll stop stand still activation by bumping the trigger.
you will feel it cut out very, very briefly a few times and the power light on the remote will flash a bit. After that happens, you probably only have 5 more rides. Get a battery and a screwdriver and a pairing key now.
if it cuts out completely on you, turn it off for 1 minute. Then you will probably be able to make it home when you turn it back on. But you can do this once only.
Yea that is a real bummer. Especially considering that I have to turn the power switch on and off more than 5 times per day, because once I ride to school, I ride it between classes. Haha. I wonder how long that will last.
