Yes. Did you get yours going ?
Nope. St-link did not work. It couldnāt connect at all on one of them. The other one was still working.
That is not good
that sucks. It should. It better work . Wtf
It is a Flipsky. Soā¦ different. Hopefully focboxes are more resilient
Iām 100% percent sure it was. I remember in detail what I did. I wanted to create a mode from my existing settings.
Iām not sure if me having ack 3.102 firmware and using his app , rather than using his firmware to read was the problem.
Will this ST-link be ok?
It seems to be the only one I can get this week (albeit at a premium 30 Euros )
U can probably borrow one from somebody
From what I understand, they are all the same if there are V2.
Ok. I ordered an ST-Link V2 from Amazon.fr
Supposedly it will be here on Wednesday so we will know if uploading the bootloader fixes the problem.
These f**ckers are getting more and more frustrating. It seems on the Focbox you have to connect directly on the PCB
I mean come on, I flew RC helis and esk8s are starting to get on my nerves more than they did.
Might luck out with a simple pin header.
Did you try to just reflash the firmaware on both of them from the vesc tool?
USB wonāt detect āblueā light only Focbox.
I dont think u suppose to flash firmware via metrā¦
Well you can. You can either do it through the app directly or use the phone as a TCP bridge. The firmware update was successful. Something else happened and bricked the vesc. Now if what you are saying if it was a good idea then I guess I agree with you. I will do all my future settings via cable.
