Hello,
I am facing an scenario where I am using a receiver/pot to control the speed of the motor. When the ADC is put to zero, the motor stops and the brakes are enabled. this is consuming some current. I am trying to disable the brakes so that the motor will be free to move as it is before powering the motor. I am also trying to do that to reduce the current consumption(for braking).
Is there a way I could disable in the app or the code? Can you point me in the place where in the code i can disable that?
Thanks!
I’m not a smart man but I know what love is. I think you can accomplish what you want in mapping. . .
I tried that but did not help.
Take a pic of what your settings are now and post them all.
Which mode are you suggesting?
Oh sorry… current no reverse with brake
I configured that settings. I looked at the RT, the issue I am having is the lowest speed is 0 and as soon as I slightly increase the pot value, it ramps to maximum. I am unable to get the speed in between the min and max value in current no brake or any other option except duty cycle. But in duty cycle I am having the issue with the brakes.
Maybe @b264 could chime in his thoughts
I think you are doing this test with wheels unloaded? They need load on them
I tried both loaded and unloaded, had the same effect. I tried changing the pot value from 2k to 10k based on recommendation from other forum and that did not help as well.
