Which part of the cables do pull on to disconnect the motors from the ESC?
Can someone circle where i am supposed to disconnect it and show me?
Or do i just yank it from the socket, where you can see in the first pic?
Do i pull it from the middle, bottom, top?
I thin you need to take the trucks off and take the component case off and diconnect them from inside. don’t just yank on stuff.
I was told i could just yank it right out after i disconnect the trucks
you need to remove the trucks either way.
I don’t like the term “yank” I would prefer if you “gently unplug”
