Hello There
I’m building an e-longboard for my graduation work. The construction progressed very well and I was able to do the first tests. So far so well there were only small problems, the idle tests worked great. Now the problem occurred when I wanted to test the board under load. The engines shook and vibrated, but didn’t turn a bit. But as soon as I pushed myself off and started to roll, they started to build up torque and it almost threw me off the board. I’m assuming there’s something wrong with the rotating field. Or that the rotating field rotates too fast, that the wheel cannot build up any torque. I would be glad if the community could help me with this problem, because there is a lot of know-how in this forum. In my board are VESC, a hub motor N6364 from China and a self-made battery pack 12S3P made of INR18650 25R cells. My remote control is a typical china model.
This are my wheels and the VESC I use one for two motors.
This is my RC.
This is my battery pack with the BMS.
My BMS Settings
My VESC settings.
Motor Settings
General
Current
Voltage
RPM
Wattage
Temperature
Advanced
BLDC Settings
General
Sensorless
Sensors
Advanced
APP Settings (However, I still think the problem is with the remote control.)
General
PPM
Mapping
Throttle Curve
Here are the RealTime Data
This shows the Current with no load attached.
This shows the Current with load attached. The Current is only 2 or 3 Amps for a motor under Load?!
Hera are the videos. This is with no load attached.
This is with load attached.I hope I have written all the necessary information and you can help me so that I can do my first manned test drives soon. I thank you in advance for your helpfulness. Thank you very much!
Nikolai2111
