that flex looks really good, maybe just a wee bit to stiff, but probably perfect for my weight. you were fairly light i remember?
amazing how thin the board is
Yeah,I am about 150 lb. can’t wait to ride on it The enclosures might be too long for the flex I hope NOT. I am planning to have 50 cells in it(10s5p) for the longer ride.
By the way, I picked up new tesseract. It’s beautiful. I guess it will be a longboard for my Son.
Nice tesseract I have been eyeing that board for quiet a while its just way to out of my budget haha
Not cheap, but the materials they used is very interesting to me. The board material is a fiberglass with epoxy skins. These are sandwiched between two layers of bamboo cores which are vertically laminated,It has some flex but stiff.
The most interesting is the bottom of the board has been laminated with a nice cork layer. It is supposed to have shock damping capabilities. We will find out.
Mastercho I’m finally getting close to doing an infusion with divinycell80 core and am wondering how many layers of triaxial Carbon to use for top and bottom. I forget the weight of what I have now but generally what would u recommend of what weight or do u have any other general advice?
I got 3m 77 spray to hold the fabric in place and will do it around the edges of the core with the carbon as apposed to how I always see people cutting the center of the mold out of overlayed fabric in generally in on plane
Or better yet how many layers of what weight is ur board made of?
I spent 2 months looking for a pot or pan big enough (40"x12") to thermoform the core and gave up and am doing multiple layers now of thinner stuff which will be able to bend in the mold.
Really like the bamboo core you did. Can u cut each veneer with the exacto?
@Hummie For the stiff deck.I would use
1 Layers of Carbon Fiber Cloth Fabric Twill 3k as cosmetic purpose. 2-3 Layers of Carbon Fiber Fabric Quadaxial 90/+45/-45/0 Degree 12k 815gsm for top and bottom Plus the core material.
If you go with 18oz/ 610gsm I would use 3-4 layers each side.
The challenge I have when I’m bagging is to make sure the bag is absolutely sealed. (I sometimes just can’t find the leak) Otherwise, you will have tiny pinholes which will weaken the board. I would do the leak test before the infusion.
I do trim the accessed fabric as well so that the bagging film is flush with the edge of the mold as a barricade to slow the resin flow from reaching the spiral vacuum tube.
4 lbs *1 layer Carbon/200gsm *4 layers Carbon18oz/ 610gsm *1 layer Fiberglass DBM 1808 Knytex Biaxial 610.31gsm sandwiched between two layers of bamboo veneer.
Yes.The bamboo is very fragile to handle until it is laminated so I was careful. There was another step I didn’t mention (no picture)was that I sliced the bamboo veneer after the cut for the resin flow. Looks like this.
Mad props sir. I was gonna make a CF deck, but i didn’t know if it was possible to make one without a foam core. I have a Hi5ber deck with a foam core that I don’t use. It’s really stiff, and i don’t like riding it. Your deck looks much nicer.
Thank you for the kind words.
I tried using a foam /honeycomb core with CF, after 20 minutes of riding it,I missed my old wood deck for some reason. Since then I have been developing flexible CF deck. The bamboo veneers help get the flex you want without sacrificing so much expensive CF cloth and epoxy resin(weight) but not as strong as the pure/full carbon,though.
Have you figured out a nice enclosure solution? I’ve ordered a Trampa Street Carver and haven’t come up with an enclosure solution I love.
2 part enclosures will do.
Did this go any further ?
The board was sold. So I did it again.
Ok what did you sell for ? Would you consider building and selling one ?
Just board itself was $150 It was pretty close to the material cost. The more I make the better I will be, right? PM me if you are interested.
following the amazing idea of mastercho, I also made a plexiglas construction thats quite versatile and I modelled the loaded vanguard concave and camber quite like the original.
not sure if I can actually press bamboo in this construction too or just mainly fibers. thought about making a tranlucent glas board for example.
the glas surface is very sturdy - 5mm thick. I think Ill try to laminate a bamboo board with that under vacuum!
THAT looks FANTASTIC! Please let us know how it works out!!
I hope someone can make a cf board like trampa with 35 degrees… getting it in the US is difficult nd could get expensive too…
Probably not the CF deck, otherwise the price will be a sky rocket ship. Fiberglass will be ideal just like Trampa board, the hardest part is to cut it in that size. I am getting a 42 inch CNC Router soon, stay tuned.
Is there a particular reason why you would prefer 35 degrees?
hi… are you still making a cf board? like a trampa style with 35 degrees?
