We get emails from several customers said the coupon code not working, i hereby make it clear for everyone, the coupon code only valid for the order amount more than 200usd. and make sure type the exactly the same coupon code as below: Black friday 15%
http://www.diyeboard.com/9-off-road-all-terrian-electric-skateboard-truck-kit-p-623.html
9’’ AT Truck Kit for our 6’’ Airless All-Terrain Wheels This 9’’ AT Truck Kit is designed for mounting our 6’’ Airless All-Terrain Wheels http://www.diyeboard.com/6-15050mm-70a-airless-allterrain-wheels-with-hubs-pulleys-p-587.html
This 9’’ AT Truck Kit is compatible with our 83*52mm wheels kit.
6’’ Airless AT wheels quick release wheel change to 83mm pu wheels
http://www.diyeboard.com/33-dual-hub-motor-electric-skateboard-7s2p-44ah-7567mm-700w-p-624.html 32’’ Swappable Battery 75mm 3’’ Dual HUB Motor Electric Skateboard 7S2P 4.4Ah Features Two custom high-powered 75mm 3’’ IN-WHEEL HUB motors with rubber wheels, 2350W. Samsung 7S2P 29.4V 4.4Ah 130Wh Swappable battery pack. All rubber AT wheels, 3’’ 7567mm size.
four hub motors, 2 controllers parralleled, one remote. accept customization preorder.
http://www.diyeboard.com/swappable-battery-pack-samsung-7s2p-130wh-with-esc-for-dual-hubs-p-625.html
Really nice design. Two questions.
- Will there be larger battery options available as well?
- Are there external chargers available?
EDIT:
- Why is no warranty offered on the ESC?
Is PU core solid or just same PU for putter wheel?
so far it is designed for 7s2p, there’s external chargers available. there’s warranty covered on esc if properlly used only with our kit.
i don’t quite understand your meaning, sorry.
On which ESC your current ESC is based as you don’t have original source code only disassembled firmware?
we have original source and based on this source code we can customize the esc based on customer’s need per their motors and batterys. so far we customized for many famous brand in this esk8 field.
I highly doubt that you guys code in assembly whole ESC algorithm… Especially math stuff…
If we as customers could program the esc our self (set current draw) for our application it would be awesome. A game changer for sure.
Could you send me a link to an external charger? Couldn’t find it on your website.
The product warranty description says that the ESC is not covered by warranty, on a pre-built device. Seems like an error.
we have app in the near future customers can adjust brake strength, speed modes, acceleration on the phone. esc is not like the vesc, it is firmware prebuilt in the pcb, to protect the electronics burn of motor and esc.
I’m looking for a charger for this battery, that doesn’t require it to be in the board: http://www.diyeboard.com/swappable-battery-pack-samsung-7s2p-130wh-with-esc-for-dual-hubs-p-625.html
Otherwise I can only charge one at a time.
http://www.diyeboard.com/294v-2a-lithium-battery-charger-for-7s-electric-skateboard-p-511.html this is the charger for this swappable battery, 7s 29.4v charger,
Thanks, i saw you have a trucks and mounts kit, what is the size of the trucks axle? (its says 9 inch) thats the whole length of the trucks right? Just whant to make sure if a 6374 motor would fit or i will reduce the motor size, fir a dual motor setup…
