I dig it. It’s weird, it’s just the Evo for me though. All of my other decks are setup opposite. The Evo is just weird.
Honestly I almost tossed it when I first built it cause it road like a big fat turd, but after experimenting with different risers and bushings and loosening the trucks more than I generally am.comfortable with this is what I came up with.
Now it’s a frikking monster. It’s the only board I have that I’m semi-comfortable at 30+ mph.
It’s funny you said that. I’m building an Arbor Highground on MBS Matrix IIs at 15 in back and 35/40 in front. No idea how it’s gonna ride but it kinda made sense in my head .
I didn’t try that, definitely worth a look. Guess I’ll give riptide some.more money .
Find your center to center distance (from pulley to pulley centers) then go to belting online and use their belt calculator. That should give you the exact belt length you need.
So, where do folks typically find larger wheel parts? Like motor mount, pulleys, etc? I know about trampa but I’d prefer a US supplier. I’m still looking to rig it together myself, but just in case. Ebay maxes out at 97mm wheel stuff.
Its got 3 pieces, a piece with a arim, a piece for the inside with no rim and another piece with a rim. You can add/remove the inside pieces all you want. I guess you could run without the outside rim but I wouldn’t. 18mm is for a 15mm belt.
Oh, that makes sense. The whole thing should fit then. Is it a problem with the pulleys being this close? Remember, this is not the same Pulley I will be using but it’s the right size. The teeth don’t match up. And on the other truck the motor mount fits closer to the center of the truck.
the first thing is to define the standard of the pulley and the belt. Are they both HTD 5M? It doesn’t look like the wheel pulley is. Does the belt fit the motor pulley?
