Do larger diameter wheels make more stable ride?
I did it wrong at first. I’ve been working the correct HTD 5M VERSION and trying to get it printed.
As long as they’re not touching, the closeness of both pulleys doesn’t matter right?
For the most part, but you want enough space that there is plenty of tooth contact on the motor pulley. You just have to test sometimes. On my ‘Glory’ build (LY Evo) there isn’t what ‘appears’ to be a lot of space and tooth contact, but there is apparently enough as it never slips and is a torque beast but I’m running 25mm pulleys and belts with dual 6374 motors.
Your build would’ve been very helpful for me before buying my recent stuff lol
how many teeth is the motor pulley?
64 teeth p
The small one on the motor. The wheel pulley is 64t
15 teeth. Sorry
Where did you get those wheels?
http://www.inlinewarehouse.com/descpage.html?pcode=900670
I spent a small fortune on them
For me 83mm is the same as 97mm wheels. O.k. on 97 you can go over bigger rocks and bla bla bla…:grinning:
But I’m riding my 83mm wheels sometimes in super bad roads. I’m riding over brunches no problem. Actually I hadn’t found road I cannot ride with my 83mm wheels.
O.k. closer to topic: so bigger wheels have nothing to do with making you feel less speed wobbles. I can suggest you from my own experience. At the beginning I had super soft bushings, even how hard I tightened them board still was curving machine. At 44km/h speed wobbles was scary as fuck, but I managed to fight them of by leaning forward and giving nearly all my weight on front wheels, leaving back leg just very light on board. Other thing is when you have wobbles you can make them stop is curve to one side and they will be gone.
But the most amazing thing how you can still have good turning board but without speed wobbles is: buy good bushings like riptide, get harder ones. I use 95A. Next is: front truck make loose and rear like 2-3 half turns tighter with skate tool. And experiment: start from super loose front and go up to your desire feeling. Just make sure rear trucks are tighter than front. With this set up your board still be able to turn as you like, but no wobbles. Of course work on your stance and power of legs too😉
Hope it helps…
These bushings are badass… 61e12656764a832329f838bb2dcc18dbfd1b3975_1_375x500
I definitely felt the difference between 76mm and 97mm. Philly has some crappy roads. And it’s pothole season. Ive been looking at those bushings. A few others said I should get some.
yeah!
Experiment and find your way whats suits you best.
Tomorrow I’ll be testing new stuff too: barrel/barrel set up with those Riptide barrels 95A.
Before I had barrel/cone set up.
Snow is halfway gone and puddles is everywhere so I will be testing my mudguards too.:smiley:
I’ll probably need to make some mud guards with my wheels. 1 thing that was confusing me is which riptide bushings I should get. I know which durometer but there are a bunch of different shapes to choose from.
Get standard size barrel, there are also tall barrels in shop, don’t take them, standard size is what you are lookin for. Now you need to decide go with barrel/barrel set up or with barrel/cone?! I tried barrel/cone set up and now I’ll be testing barrel/barrel set up. Barrel/cone is less stable in theory, I’ll test tomorrow and will see.
If you need help with bushings talk to Brad from riptide in the “bushing set up” thread, I mean you can’t get any better than talking to the guy who makes them!
I feel like I don’t have enough info for him. I don’t actually know how it will rude with my truck/wheel changes. I haven’t even tried tightening the back and loosening the front yet.
He is the pro Sapphi, I’d let him make that decision. Have a read of the topic and give him what you can. Likely he might save you money in not having to try a zillion combinations to get your setup right. We really are lucky to have him here helping. Brad has already seen and liked my post suggesting you ask him in his “bushing set up” thread so I think it is fair to say he is happy to help you.
He said what I thought lol
Yay, I can confirm my latest version fits. I’m hoping @akhlut can make it in metal for me. This print came out better somehow too.
