I have 2 192kv motors that recommend to only use a 10-12s setup to power them, but there is a bms I saw on GreatScott’s ebike battery video I’d like to get that is 13s, and then I’d make a 13s4p configuration.
I know that I can use the VESC tool to set the max voltage to be within the motors’ acceptable voltage range, but how is the power coming from the battery reduced? Is it being step down with a buck converter to get lower voltage/higher amperage, or is the extra energy just converted to heat through some LDO regulator? Does anyone have any knowledge of the actual mechanism that limits the motors’ voltage?
Whatever limit you’re referring to probably just shuts down the entire ESC. There is no voltage clamping. That would be the job of a BMS if it were to exist, and not of the ESC.
i think sub 11s is just a safe rule of thumb to follow, to make sure you don’t blow your chips. you are right, there are definitely people who surpass it
This is really just adjusting the average voltage though yes? I mean it’s still at whatever voltage it’s at just for shorter periods giving a lower average but if the components have low capacitance then it is still spiking the voltage up to whatever is coming in.
@slade you can limit the amperage which will effectively keep your components safe. Amperage is what results in heat loss and wears on components ultimately so limiting it allows you to keep the battery and motor in safe limits. I believe the vesc simply limits the duty cycle in order to keep the amperage within limits you set. That said believe the MOSFETs or drv chip are rated for 60V maximum buy would need to pull up the datasheet.
Why the hell would you do that. Lol. We all want 100% duty and are stuck at 95%. No way in any shape or form would I lower max duty, that’s just bonkers
