Ok, so I’ve decided to do a high end build… and I’m been reading a lot but still have a couple questions…
I bought the evolve trucks and AT wheels/kit along with the motor mounts from https://www.unikboards.com/en/boutique/core-serie-support-moteur-pour-truck-evolve-supercarve-street-et-at/
and I understand I need 63mm motors for this to work… so Id like to use some focbox’s and have a 10s5p battery coming… so from reading for my battery pack I should stay around a 200kv?? so im thinking the Sensored 6369 200kv motor is what I should get correct? or any other advice would be helpful… thanks!
It will have a little arrow pointing to the persons icon if te post is a few up, or if they are responding to the last post made it wont have the arrow
Can confirm; two real 6374 motors WILL fit on the Supercarve trucks but the Turnigy sk3 “6374” motors are not 6374 and they will not fit. They are 5984…
Just look at the motor dimensions and if it’s more then 76mm long it won’t fit
awesome, im about to buy some now from torque… is there adapters for the bullet’s? because focbox bullet connectors is 3.5mm and the torque 6375 motors are 5.5mm?
